[QGIS-trac] Re: [Quantum GIS] #1141: broken Polish characters support since r8592
Quantum GIS qgis at qgis.org
Mon Jul 7 07:31:58 EDT 2008
        Reporter:  msieczka                                   |         Owner:  jef
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 0.10.0
       Component:  Internationalisation                       |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by msieczka):
 Correction - the query/edit issue applies only to GRASS vector layers.
 Polish chars are handled OK in case of Shapefiles tables.
 As to Shapefiles, only the issue with saving it under a name with non-
 ASCII chars applies - eg. if I create a new Shapefile and try save it as
 "test_ąę", it will be saved as "test_".
 Also I noticed that QGIS silently fails to create fields with non-ASCII
 chars when createing a new shapefile. Please issue an error instead.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1141#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
