[QGIS-trac] Re: [Quantum GIS] #978: topological editing with snapping to segment yields 2 vertices instead of 1 adding vertex
Quantum GIS qgis at qgis.org
Fri Jul 11 03:49:09 EDT 2008
adding vertex
        Reporter:  msieczka                                   |         Owner:  timlinux
            Type:  bug                                        |        Status:  reopened
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 0.11.0
       Component:  Digitising                                 |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by msieczka):
 Tim,
 I can still reproduce the bug in latest trunk r8750. Follow this please:
 1. Open the attached shapefile in QGIS.
 2. Project properties: check "Enable topological editing".
 3. Project properties > Snapping options: check the layer, Mode: "to
 vertex and segment", Tolerance: "10".
 4. Toggle editing.
 5. Add a vertex, move it - you'll see 3 vertices were added instead of 1.
 The attached screendumps show that it really happens.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/978#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
