[QGIS-trac] Re: [Quantum GIS] #1149: right clicking on attribute table of point file seg faults
Quantum GIS qgis at qgis.org
Fri Jul 11 13:55:52 EDT 2008
        Reporter:  arkygeek                                   |         Owner:  nobody
            Type:  defect                                     |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 0.11.0
       Component:  OGR Layer support                          |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  postgis select shapefile
Platform_version:                                             |      Platform:  Debian
        Must_fix:  Yes                                        |   Status_info:  0
Changes (by timlinux):
  * status:  new => closed
  * resolution:  => fixed
Old description:
> when selectin multiple features from a postgis layer and right clicking
> to save to shapefile, immediate seg fault.
> arkygeek at arkygeek-desktop:~/apps/qgis/bin$ ./qgis
> Debug:
> Debug: QgsApplication state:
> Debug: Prefix       :/home/arkygeek/apps/qgis
> Debug: Plugin Path  :/home/arkygeek/apps/qgis/lib/qgis
> Debug: PkgData Path :/home/arkygeek/apps/qgis/share/qgis
> Debug: Theme Path   :/home/arkygeek/apps/qgis/share/qgis/themes/default/
> Debug: User DB Path
> :/home/arkygeek/apps/qgis/share/qgis/resources/qgis.db
> Debug: **********************************
> Warning: No valid projection. Unable to set map units.
> Debug:
> Debug: User DB Path
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libcopyrightlabelplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libdelimitedtextplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libdelimitedtextprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libgeorefplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libgpsimporterplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libgpxprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libgrassplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libgrassprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libgridmakerplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libmemoryprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libnortharrowplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libogrprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libpggeoprocessingplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libpostgresprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libquickprintplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libscalebarplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libspitplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libwfsplugin.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libwfsprovider.so
> Loaded /home/arkygeek/apps/qgis/lib/qgis/libwmsprovider.so
> Debug: current properties:
> Debug: name: properties
> Debug:  key: <GRASS>  subkey: <GRASS>
> Debug:          name: GRASS
> Debug:                  key: <WorkingLocation>  value: shuna
> Debug:                  key: <WorkingGisdbase>  value:
> /home/arkygeek/GRASSDATA
> Debug:                  key: <WorkingMapset>  value: shuna
> Debug:  key: <Gui>  subkey: <Gui>
> Debug:          name: Gui
> Debug:                  key: <SelectionColorBluePart>  value: 0
> Debug:                  key: <CanvasColorGreenPart>  value: 255
> Debug:                  key: <CanvasColorRedPart>  value: 255
> Debug:                  key: <SelectionColorRedPart>  value: 255
> Debug:                  key: <SelectionColorGreenPart>  value: 255
> Debug:                  key: <CanvasColorBluePart>  value: 255
> Debug:  key: <PositionPrecision>  subkey: <PositionPrecision>
> Debug:          name: PositionPrecision
> Debug:                  key: <DecimalPlaces>  value: 2
> Debug:                  key: <Automatic>  value: true
> Debug: /home/arkygeek/devel/qgis_unstable/src/core/qgsproject.cpp : 558
> unable to find title element
> Warning: QFSFileEngine::open: No file name specified
> --accepting rule at line 79 ("siteno")
> --accepting rule at line 61 ("=")
> --accepting rule at line 75 ("2221001")
> --accepting rule at line 81 (" ")
> --accepting rule at line 59 ("OR")
> --accepting rule at line 75 ("2020012")
> --accepting rule at line 75 ("2221017")
> --accepting rule at line 75 ("2323009")
> --accepting rule at line 75 ("2021030")
> --accepting rule at line 75 ("2121065")
> --accepting rule at line 75 ("2120049")
> --accepting rule at line 75 ("2321002")
> --accepting rule at line 75 ("2021039")
> --accepting rule at line 75 ("2321003")
> --(end of buffer or a NUL)
> --accepting rule at line 75 ("2021013")
> --EOF (start condition 0)
> Segmentation fault
New description:
 when selectin multiple features from a postgis layer and right clicking to
 Debug:
 Debug: User DB Path :/home/arkygeek/apps/qgis/share/qgis/resources/qgis.db
 Debug:
 Debug:          name: GRASS
 Debug:          name: Gui
 Segmentation fault
Comment:
 Fix with r8754.. At times the current row can be returned as -1 which will
 cause a crash if you try to fetch its display role. The fix checks for
 invalid row numbers and skips fetching data for them if this is the case.
 May result in edge cases where user clicks and attribute actions are not
 invoked.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1149#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
