[QGIS-trac] Re: [Quantum GIS] #960: Area scale field: make standardized symbol dimension and legend
Quantum GIS qgis at qgis.org
Mon Jul 14 19:35:17 EDT 2008
        Reporter:  giohappy                         |         Owner:  homann
            Type:  enhancement                      |        Status:  new
        Priority:  minor: annoyance or enhancement  |     Milestone:  Version 1.0.0
       Component:  Symbology                        |       Version:  HEAD
      Resolution:                                   |      Keywords:  area scale field, graduated points
Platform_version:                                   |      Platform:  All
        Must_fix:  No                               |   Status_info:  1
Comment (by giohappy):
 Hi Tim.
 I'm referring to the symbology option for punctual features, that lets you
 choose a single layer whose dimension (and rotation) may be controlled by
 means of a selected attribute.
 You can choose a not better defined "dimension" factor that applies to the
 symbols size proportionally to the attribute value. Now, if you have huge
 values you can get enormous balloons even if you set the minimum
 "dimension" (by default the lower limit is 3).
 I think it could be better to stanrdardize the dimensions of the symbols
 on the basis of a minimum-maximum value.
 In this way the user could choose the best visualization it needs.
 In formula it could be:
 (attribute_value - min_dimension)/(max_dimension-min_dimension)
 or something similar...
Ticket URL: <http://trac.osgeo.org/qgis/ticket/960#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
