[QGIS-trac] [Quantum GIS] #1164: Packaging error - Ubuntu Hardy 0.11.0
Quantum GIS qgis at qgis.org
Thu Jul 17 14:39:45 EDT 2008
   Reporter:  morgan                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 0.11.0
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:  ubuntu package                    |   Platform_version:
   Platform:  Linux                             |           Must_fix:  No
Status_info:  0                                 |
 Using Kubuntu 8.04.1 i386 from the qgis repo
 The upgrade to 0.11.0 seems to have worked, but libqgis1-dev won't update.
 Adept-updater says broken (conflict)
 then, in the details, says:
 Replaces: qgis-dev
 Conflict: qgis-dev
 Conflict: libqgis-dev
 apt-get upgrade:
 $ sudo apt-get upgrade
 Reading package lists... Done
 Building dependency tree
 Reading state information... Done
 You might want to run `apt-get -f install' to correct these.
 The following packages have unmet dependencies:
   libqgis1-dev: Depends: qgis (= 0.10.0-6~hardy) but 0.11.0-1~hardy1 is
 installed
 E: Unmet dependencies. Try using -f.
 $ sudo apt-get -f install
 Correcting dependencies... Done
 The following packages were automatically installed and are no longer
 required:
   libqgis-gui0.10 xserver-xorg-video-amd libflashsupport libqgisgrass0.10
   libdns32 linux-headers-2.6.24-17-generic libqgis-core0.10
   linux-headers-2.6.24-18-generic libgsl0 linux-headers-2.6.24-16-generic
   linux-headers-2.6.24-16 linux-headers-2.6.24-17 linux-headers-2.6.24-18
 Use 'apt-get autoremove' to remove them.
 The following extra packages will be installed:
   libqgis1-dev
 The following packages will be upgraded:
   libqgis1-dev
 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
 Need to get 0B/139kB of archives.
 After this operation, 20.5kB of additional disk space will be used.
 Do you want to continue [Y/n]?
 WARNING: The following packages cannot be authenticated!
   libqgis1-dev
 Install these packages without verification [y/N]? y
 (Reading database ... 207250 files and directories currently installed.)
 Preparing to replace libqgis1-dev 0.10.0-6~hardy (using .../libqgis1-
 dev_0.11.0-1~hardy1_i386.deb) ...
 Unpacking replacement libqgis1-dev ...
 dpkg: error processing /var/cache/apt/archives/libqgis1-
 dev_0.11.0-1~hardy1_i386.deb (--unpack):
  trying to overwrite `/usr/lib/libqgisgrass.so', which is also in package
 libqgisgrass0.10
 Errors were encountered while processing:
  /var/cache/apt/archives/libqgis1-dev_0.11.0-1~hardy1_i386.deb
 E: Sub-process /usr/bin/dpkg returned an error code (1)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1164>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
