[QGIS-trac] [Quantum GIS] #1178: QGIS 0.11.0 crashes when using print composer
Quantum GIS qgis at qgis.org
Wed Jul 23 16:00:10 EDT 2008
   Reporter:  morgan                                     |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  Printing                                   |            Version:  0.11.0
   Keywords:  printing ubuntu kde kubuntu                |   Platform_version:
   Platform:  Linux                                      |           Must_fix:  No
Status_info:  0                                          |
 I am having exactly the same problem I reported
 [https://trac.osgeo.org/qgis/ticket/1128/ in 0.10.0], now using 0.11.0
 from the launchpad repo in kubuntu 8.04.
 I do:
 File>>Print
 Print composer opens
 I click "add map" and draw a box
 QGIS never draws the map. Nothing happens for 3 or 4 seconds, then QGIS
 crashes without warning or any feedback at all.
 I'm using a mix of PostGIS and Shapefile layers.
 Troubleshooters could download ''some'' of the shapefiles I use
 [http://www.alleghenycounty.us/dcs/gis/available.aspx/ here], but I can't
 make the PostGIS databases public (as they contain personal info)
 Here is the output when I run this from the command line
 Note that this mentions WGS84. Everything I use is NAD83, and I have
 expressly set that both as the global default and have QGIS set to promt
 for projection when the layer doesn't contain the info.
 Warning: No valid projection. Unable to set map units.
 SpatialRefSys/ProjectSRSProj4String: +proj=longlat +ellps=WGS84
 +datum=WGS84 +no_defs
 Warning: Throwing exception
 /build/buildd/qgis-0.11.0/src/core/qgscoordinatetransform.cpp502
 /build/buildd/qgis-0.11.0/src/core/qgscoordinatetransform.cpp225
 /build/buildd/qgis-0.11.0/src/core/qgscoordinatetransform.cpp245
 Warning: Transform error caught in
 /build/buildd/qgis-0.11.0/src/core/qgsmaprender.cpp, line 544
 SpatialRefSys/ProjectSRSProj4String: +proj=longlat +ellps=GRS80
 +datum=NAD83 +no_defs
 Warning: QPaintEngine::setSystemClip: Should not be changed while engine
 is active
 is active
 Warning: QWidgetPrivate::beginSharedPainter: Painter is already active
 Warning: QPainter::begin: A paint device can only be painted by one
 painter at a time.
 is active
 Warning: QPaintEngine::setSystemRect: Should not be changed while engine
 is active
 '''------------the two above alternate for several pages---------------'''
 is active
 is active
 is active
 Warning: QPainter::clipPath: Painter not active
 Warning: QPainter::save: Painter not active
 Warning: QPainter::resetMatrix: Painter not active
 Warning: QPainter::restore: Painter not active
 Segmentation fault
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1178>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
