[QGIS-trac] [Quantum GIS] #1196: projection parameter +no_uoff is not applied to layer SRS; affects Michigan GeoRef
Quantum GIS qgis at qgis.org
Thu Jul 31 20:39:40 EDT 2008
GeoRef
   Reporter:  smizuno                           |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  Projection Support                |            Version:  HEAD
   Keywords:  projection georef                 |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 background: the PROJ.4 definitions for Michigan GeoRef (EPSG:3078, 3079)
 don't work properly unless +no_uoff is included in the definition. There
 is PROJ.4 mailing list traffic about this.
 A Custom Projection can be created for Michigan GeoRef by copying the 3078
 parameters and adding +no_uoff. This can be saved ok and the parameters
 test ok.
 When this custom projection is applied to a layer the +no_uoff parameter
 disappears from the SRS string on the General tab of layer properties and
 the layer is not projected properly.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1196>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
