[QGIS-trac] [Quantum GIS] #1131: shapefile export of PostGIS layer: field size for integer is too small
Quantum GIS qgis at qgis.org
Tue Jun 24 05:15:17 EDT 2008
   Reporter:  best                              |              Owner:  nobody
       Type:  defect                            |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Data Provider                     |            Version:  0.10.0
   Keywords:  Shapefile field size              |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 Any integer field in a PostGIS table is exported as numeric with 4 digits
 only in the dbf-file, resulting in a data loss for numbers larger than
 9999. The table view in QGIS shows the correct numbers, though.
 Defect has been reproduced on Win2K and OpenSuse 10.3, so I assume all
 platforms are affected. Server is Postgres 8.2.4 with PostGIS 1.2.1.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1131>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
