[QGIS-trac] [Quantum GIS] #1132: Layers not displaying
Quantum GIS qgis at qgis.org
Sat Jun 28 08:57:39 EDT 2008
   Reporter:  Herb                              |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Graphics                          |            Version:  HEAD
   Keywords:  projection                        |   Platform_version:
   Platform:  Linux                             |           Must_fix:  No
Status_info:  0                                 |
 I'm having a problem with layers not displaying in Qgis Io. This is for
 both raster and vector layers with QGIS SRSID: 219. The layers have been
 loaded and selected and the projection set correctly. To make the layer
 display whenever Qgis is started, I have to go to the Layer Projection
 Selector (where the correct projection is already highlighted) and click
 OK. The layer then displays correctly. This needs to be done each time I
 open a project with Qgis.
 This began when I updated to Io. It's not a problem for layers with other
 SRSID, for example, 2585. The problem layers seem to be correctly defined
 in the .qgs file. A sample shapefile and .qgs file are attached.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1132>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
