[QGIS-trac] Re: [Quantum GIS] #1128: QGIS 0.10.0 crashes when using print composer
Quantum GIS qgis at qgis.org
Mon Jun 30 12:08:05 EDT 2008
        Reporter:  morgan                                     |         Owner:  nobody
            Type:  defect                                     |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:
       Component:  Printing                                   |       Version:  0.10.0
      Resolution:                                             |      Keywords:  print composer, ubuntu, kde, kubuntu, print, printing
Platform_version:  Ubuntu 8.04                                |      Platform:  Linux
        Must_fix:  No                                         |   Status_info:  0
Comment (by cuz):
 Well, I'm confused. All I can do is give you results. Using this shapefile
 (http://www.census.gov/geo/cob/bdy/st/st00shp/st99_d00_shp.zip), the crash
 occurs. Using other shapefiles (like
 http://drake.gisc.berkeley.edu/urbandata/Files/Shapefiles/Boundary,%20Census%20&%20Administrative%20Shapefiles%20&%20Data/Counties.zip)
 produces no problem. Also, after importing the problem file into postGIS
 using shp2pgsql, it saves to png without a problem. Perhaps this means
 it's a malformed shapefile?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1128#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
