[QGIS-trac] [Quantum GIS] #1087: adding postgis data with geometry field based on a domain and not a simple geometry type
Quantum GIS qgis at qgis.org
Wed May 14 07:22:30 EDT 2008
geometry type
   Reporter:  zawardo                           |              Owner:  nobody
       Type:  defect                            |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Data Provider                     |            Version:
   Keywords:  postgis domain                    |   Platform_version:  0.10
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 I've noticed a strange behaviour when adding a postgis layer into the
 project:
 i connect to my db and i can only select the tables with a geometry field
 definied by a simple geometry type. If i want to add a table which have
 the geometry field definied as a domain (geometry type plus some checks)
 it is not recognized as an addable data.
 Since i'm going to use a rather large postgis dataset heavy domain-
 dependent and i'd have appreciated to use qgis with that data it's quite
 an issue for me. Are you planning to support postgis domain types anytime
 soon?
 thank you very much for your work.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1087>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
