[QGIS-trac] [Quantum GIS] #1101: GRASS Toolbox Enhancements
Quantum GIS qgis at qgis.org
Wed May 21 04:12:00 EDT 2008
   Reporter:  marcopx                           |              Owner:  nobody
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0
  Component:  GRASS                             |            Version:  HEAD
   Keywords:  grass toolbox                     |   Platform_version:  All
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 Hi all,
 Even if I named the short summary as "Enhancement", some changes to the
 qgm GRASS modules I'm proposing here are in fact major priorities, since
 many modules don't work as expected/needed.
 A brief summary of the previous job, already posted to the list:
 New/modified/renamed modules introduced in the previous job:
 - g.region.save
 - g.region.zoom
 - g.region.multiple.raster
 - g.region.multiple.vector
 - r.patch
 - v.patch
 - r.proj
 - r.proj.res
 - v.in.db
 - v.in.ogr
 - v.in.ogr.loc
 - v.in.ogr.all
 - v.in.ogr.all.loc
 - v.in.shape
 - v.in.shape.loc
 for more details on the changes listed above, see:
 http://lists.osgeo.org/pipermail/qgis-developer/2008-May/003797.html
 News in the current job:
 I modified descriptions of some g.proj modules (IMHO not correctly
 reflecting the real job of the modules) and added the g.proj.ascii module
 for coherency:
 Module - New description
 - g.proj.print - Print projection information of the current location
 - g.proj.geo - Print projection information from a georeferenced file
 (raster, vector or image)
 - g.proj.ascii - Print projection information from a georeferenced ASCII
 file containing a WKT projection description
 - g.proj.proj - Print projection information from a PROJ.4 projection
 description file
 - g.proj.geo.new - Print projection information from a georeferenced file
 (raster, vector or image) and create a new location based on it
 - g.proj.ascii.new - Print projection information from a georeferenced
 ASCII file containing a WKT projection description and create a new
 - g.proj.proj.new - Print projection information from a PROJ.4 projection
 description file and create a new location based on it
 Then I found that the g.proj.region is not included in the default.qgc
 configuration file, and that it is actually an useless module
 As usual, all the changes have been tested on the svn 0.10.0 release code.
 Summarizing, I suggest to test as follows:
 1. remove g.proj.region (.qgm + .1.png) [not included in
 ./config/default.qgc and actually useless]
 2. remove g.region (.qgm + .1.png) [replaced by g.proj.save]
 3. remove g.proj.print.2.png [according to the new ./config/default.qgc
 layout, where I *normalized* the tree]
 4. add the new modules (extract the zip to ../src/plugins/grass/modules
 and modify the ./config/default.qgc patching the svn qgis-trunk diff
 attached]
 run cmakesetup .. to apply the changes in default.qgc, then build
 Best regards,
 Marco
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1101>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
