[QGIS-trac] Re: [Quantum GIS] #1092: Map Print Composer - can't add map
Quantum GIS qgis at qgis.org
Wed May 21 11:37:02 EDT 2008
        Reporter:  williamskg6                      |         Owner:  nobody
            Type:  enhancement                      |        Status:  new
        Priority:  minor: annoyance or enhancement  |     Milestone:  Version 1.0
       Component:  Printing                         |       Version:  HEAD
      Resolution:                                   |      Keywords:
Platform_version:  XP SP2                           |      Platform:  Windows
        Must_fix:  No                               |   Status_info:  0
Changes (by marcopx):
  * priority:  major: does not work as expected => minor: annoyance or
               enhancement
  * type:  defect => enhancement
  * milestone:  => Version 1.0
Comment:
 Replying to [ticket:1092 williamskg6]:
 > In Windows QGIS 0.10.0, the Print Composer will not let the user add a
 new map.  Click on the button, nothing happens.  Attempt to click or drag
 a box in the composer area - nothing happens.
 > Add an image opens a dialog but doesn't add an image (no map to put it
 on).
 > Add a new label does nothing when clicked on.
 > Add a new vect. legend does nothing when clicked on.
 > Add a new scalebar does nothing when clicked on.
 After pressing the function button you must go to the map layout and just
 click.
 It works for every item mentioned above (map, image, label, legend and
 scalebar)
 The only things that we should probably add are:
 1. let user resize the objects using the mouse pointer (such as in AutoCAD
 layout composer)
 2. show an info label function on-mouse-over the objects, showing out
 their names (such as "Map1", and so on...); it would be very useful if you
 are creating a map layout with multiple map tiles
 IMHO
 Marco
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1092#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
