[QGIS-trac] Re: [Quantum GIS] #1035: automated generation of srs.db (in line with postgis, proj and gdal)
Quantum GIS qgis at qgis.org
Mon May 26 10:10:58 EDT 2008
        Reporter:  rduivenvoorde                    |         Owner:  nobody
            Type:  enhancement                      |        Status:  new
        Priority:  minor: annoyance or enhancement  |     Milestone:
       Component:  Build/Install                    |       Version:  HEAD
      Resolution:                                   |      Keywords:  srs.db projection
Platform_version:                                   |      Platform:  All
        Must_fix:  No                               |   Status_info:  0
Comment (by hamish):
 Paul Kelly wrote on the grass-users list:
 > There are actually only a few +datum= codes recognised by
 > PROJ.4 - most of them are specific to GRASS. So it isn't
 > meaningful to include a +datum=xxxx if the PROJ string is
 > destined to be used by something other than GRASS. The OGR
 > functions that GRASS uses to interpret EPSG codes somehow
 > manage to return the full EPSG name for the datum, which is
 > then compared to GRASS's datum.table (the second field in this
 > table holds the full EPSG name). Combined with
 > datumtransform.table that gives GRASS enough information to go
 > on to present the user with a choice of datum transform
 > paramteters. However the full EPSG name isn't included in the
 > PROJ.4 string, and if that is all QGIS is using then maybe
 > that's where its deficiency stems from. It is all very messy
 > and complicated.
 > Paul
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1035#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
