[QGIS-trac] [Quantum GIS] #1111: mapfile export - some issues
Quantum GIS qgis at qgis.org
Mon May 26 17:15:46 EDT 2008
   Reporter:  mschulz                          |              Owner:  gsherman
       Type:  enhancement                      |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.0
  Component:  MapServer export                 |            Version:  HEAD
   Keywords:                                   |   Platform_version:
   Platform:  All                              |           Must_fix:  No
Status_info:  0                                |
 Mapfile export with the python plugin in "io" has some flaws. I tried
 patching some of them, and will attach the changed files:
 - export of postgis statements was wrong (see ticket #1104)[[BR]]
 - export of layers only still writes whole mapfile[[BR]]
 - export uses proj4 string to create mapfile projection element[[BR]]
 - export doesn't distinguish between mapfile projection and layer
 projection[[BR]]
 - symbology creation changed wrt. to geometry type (e.g. WIDTH instead of
 SIZE, OUTLINECOLOR instead of FILLCOLOR)[[BR]]
 - export dialog select box "units" shouldn't translate UNITS values[[BR]]
 Use whatever you want from the suggested changes. Cheers, Michael
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1111>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
