[QGIS-trac] [Quantum GIS] #1119: Display field does not stick in general tab of layer properties
Quantum GIS qgis at qgis.org
Thu May 29 14:26:37 EDT 2008
   Reporter:  jctull                                    |              Owner:  nobody
       Type:  defect                                    |             Status:  new
   Priority:  minor: annoyance or enhancement           |          Milestone:
  Component:  GUI                                       |            Version:  HEAD
   Keywords:  display field general properties tooltip  |   Platform_version:  10.5.3
   Platform:  OS X                                      |           Must_fix:  Yes
Status_info:  0                                         |
 For shapefiles, when changing the "Display Field" item under the General
 tab of the layer properties, the drop-down menu always shows the first
 field once the layer properties dialog has been closed and reopened. The
 drop-down should display the last selected item instead. This only occurs
 after closing the dialog, not when switching between tabs of an open
 dialog.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1119>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
