[QGIS-trac] Re: [Quantum GIS] #1035: automated generation of srs.db (in line with postgis, proj and gdal)
Quantum GIS qgis at qgis.org
Fri May 30 09:19:38 EDT 2008
        Reporter:  rduivenvoorde                    |         Owner:  nobody
            Type:  enhancement                      |        Status:  new
        Priority:  minor: annoyance or enhancement  |     Milestone:
       Component:  Build/Install                    |       Version:  HEAD
      Resolution:                                   |      Keywords:  srs.db projection
Platform_version:                                   |      Platform:  All
        Must_fix:  No                               |   Status_info:  0
Comment (by msieczka):
 Replying to [comment:8 hamish]:
 >  * SRS [+init=epsg:1234] - spatial reference system (eg the EPSG codes)
 a commonly used
 > combination of a projection, datum and/or ellipsoid, false eastings &
 northings, etc.  Strictly > speaking the "projection" is just the +proj=
 part, not the whole SRS even though it is often
 > called that.
 And it should not be called that. "Projection" is merely a component of a
 "spatial reference system" aka "coordinate system".
 > and some old ones like:
 > # Dabola 1981 / UTM zone 28N (deprecated)
 "Deprecated" are "broken" rather than "old ones". They are kept in the
 EPSG database though for keeping the track of changes. Eg. 2171 is
 "deprecated" because it has a huge error. It's valid counterpart was added
 as 3120, about a year ago.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1035#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
