[QGIS-trac] Re: [Quantum GIS] #1339: Can't set projection to WGS84 UTM Zone 15N
Quantum GIS qgis at qgis.org
Sat Nov 1 18:54:53 EDT 2008
        Reporter:  vedgewater                        |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Projection Support                |       Version:  0.11.0
      Resolution:                                    |      Keywords:  UTM SRSID
Platform_version:                                    |      Platform:  Gentoo
        Must_fix:  No                                |   Status_info:  0
Comment (by vedgewater):
 Hi Fernando,
 Thanks for your help, I can use the code you posted without needing to use
 the "save layer as" workaround in my previous post.  It's returning the
 correct SRS now.
 I guess returning vlayer in my original code was the problem.
 I shall update my code now...
 Shall I make as resolved (fixed) ?
 Regards,
 Vince
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1339#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
