[QGIS-trac] Re: [Quantum GIS] #1333: QGIS measure tools
Quantum GIS qgis at qgis.org
Mon Nov 3 09:25:49 EST 2008
        Reporter:  stelmo                            |         Owner:  homann
            Type:  bug                               |        Status:  assigned
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  GUI                               |       Version:  HEAD
      Resolution:                                    |      Keywords:  QGIS Mesaure Tools
Platform_version:  WindowsXP SP2                     |      Platform:  Windows
        Must_fix:  Yes                               |   Status_info:  1
Changes (by lhbecker):
  * platform_version:  => WindowsXP SP2
  * priority:  critical: causes crash or data corruption => major: does not
               work as expected
  * component:  Build/Install => GUI
  * keywords:  => QGIS Mesaure Tools
  * must_fix:  No => Yes
Comment:
 Hi
 I also have a problem with the measureing tool on Windows. I don't know if
 I use it wrongly, but I experienced the same problem on both 0.11.0 and
 1.0.0. I changed the Settings -> Project Properties -> Map Units to Meters
 (from degrees) in the hope that the measuring tool would display the
 measured distance in meters. Although the measurement popup show that the
 units are meters, that actual displayed distance is the same as was shown
 for the degrees. The some problem persists if I you change the units to
 feet. If I remember correctly, it work fine on my Mac OS X Tiger at home.
 Regard
 Louis Becker
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1333#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
