[QGIS-trac] [Quantum GIS] #1382: Attribute table doesn't refresh
Quantum GIS qgis at qgis.org
Wed Nov 5 07:54:10 EST 2008
   Reporter:  cmoe                              |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  GUI                               |            Version:  HEAD
   Keywords:  attribute table, refresh          |   Platform_version:
   Platform:  RedHat                            |           Must_fix:  Yes
Status_info:  0                                 |
 I guess, I have some issue found, working with the attribute table.
 a) I have a line layer (shapefile) loaded. If I select a feature and open
 the attribute table, I get one marked row with the correct attributes to
 the feature, but the whole layer isn't shown anymore in the map. A refresh
 of the map solves the problem then.
 b) Do as in a), then: If I now select an other feature (the attribute
 table still open) the feature gets marked as selected in the map, but the
 attribute table doesn't show the correct attributes. It still shows the
 attributes of the first feature, altough it unmarked it in the attributes
 table.
 This is very confusing. One has to be very careful not to work with wrong
 attributes, since the missing refresh isn't easy to see if the attributes
 are similar.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1382>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
