[QGIS-trac] [Quantum GIS] #1416: crash querying very small GRASS vector polygon
Quantum GIS qgis at qgis.org
Thu Nov 20 19:14:43 EST 2008
   Reporter:  msieczka                                   |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.0.0
  Component:  GRASS                                      |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  Yes
Status_info:  0                                          |
 amd64 Debian testing, QT 4.4.3, QGIS trunk r9668
 I have a very small polygon in my GRASS vector map. If I try to query it
 with identify tool when
 it's veray small on my screen (few pixels, hardly visible) QGIS crashes as
 below. No crash if I zoom close enough to see the polygon fill and then
 query.
 Debug:
 Debug: /home/shoofi/src/straight/qgis-
 trunk/src/core/qgscoordinatereferencesystem.cpp: 189: (loadFromDb) load
 CRS from /usr/local/qgis/share/qgis/resources/srs.db where epsg is 4326
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1060: (openDb) path =
 trunk/src/core/qgscoordinatereferencesystem.cpp: 719: (setMapUnits)
 Projection has angular units of degree
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1091: (debugPrint)
 ***SpatialRefSystem***
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1092: (debugPrint) *
 Valid : true
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1093: (debugPrint) *
 SrsId : 3344
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1094: (debugPrint) *
 Proj4 : +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1095: (debugPrint) *
 Desc. : WGS 84
 trunk/src/core/qgscoordinatereferencesystem.cpp: 1106: (debugPrint) *
 Units : degrees
 trunk/src/core/qgscoordinatereferencesystem.cpp: 363: (createFromProj4)
 wholetext match on name failed, trying proj4string match
 trunk/src/core/qgscoordinatereferencesystem.cpp: 450: (getRecord) running
 query: select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84
 +datum=WGS84 +no_defs'
 trunk/src/core/qgscoordinatereferencesystem.cpp: 472: (getRecord) trying
 system srs.db
 trunk/src/core/qgscoordinatereferencesystem.cpp: 527: (getRecord)
 retrieved:  select * from tbl_srs where parameters='+proj=longlat
 +ellps=WGS84 +datum=WGS84 +no_defs'
 trunk/src/core/qgscoordinatereferencesystem.cpp: 368: (createFromProj4)
 proj4string match search for srsid returned srsid: 3344
 CRS from /usr/local/qgis/share/qgis/resources/srs.db where srs_id is 3344
 Valid : true
 SrsId : 3344
 Desc. : WGS 84
 Units : degrees
 trunk/src/core/qgscoordinatetransform.cpp: 194: (initialise) Source/Dest
 CRS equal, shortcircuit is set.
 Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsdistancearea.cpp:
 156: (setEllipsoid) setEllipsoid: a=™, b=˜, 1/f=*
 +no_defs'
 system srs.db
 +ellps=WGS84 +no_defs'
 proj4string match search for srsid returned srsid: 3132
 CRS from /usr/local/qgis/share/qgis/resources/srs.db where srs_id is 3132
 Valid : true
 SrsId : 3132
 Proj4 : +proj=longlat +ellps=WGS84 +no_defs
 Desc. : Unknown datum based upon the WGS 84 ellipsoid
 Units : degrees
 trunk/src/core/qgscoordinatetransform.cpp: 109: (setDestCRS) entered.
 +no_defs'
 system srs.db
 Valid : true
 SrsId : 3132
 Units : degrees
 Valid : true
 SrsId : 3344
 Desc. : WGS 84
 Units : degrees
 trunk/src/providers/grass/qgsgrassprovider.cpp: 544: (fieldCount) return:
 1
 trunk/src/providers/grass/qgsgrassprovider.cpp: 1160: (mapOutdated)
 entered.
 trunk/src/providers/grass/qgsgrassprovider.cpp: 1186: (attributesOutdated)
 entered.
 trunk/src/providers/grass/qgsgrassprovider.cpp: 420: (resetSelection)
 entered.
 Backtrace:
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0x7ff02e55c710 (LWP 4808)]
 0x00007ff01c7a688a in dig_alloc_points (points=0x0, num=1)
     at struct_alloc.c:237
 237         alloced = points->alloc_points;
 Current language:  auto; currently c
 (gdb) bt
 #0  0x00007ff01c7a688a in dig_alloc_points (points=0x0, num=1)
 #1  0x00007ff01c9cea8b in Vect_copy_xyz_to_pnts (Points=0x0,
 x=0x7fff36695e10,
     y=0x7fff36695e08, z=0x7fff36695e00, n=1) at line.c:118
 #2  0x00007ff01c9cd54d in find_cross (id=2, arg=0x7fff36695f34)
     at intersect.c:1095
 #3  0x00007ff01bd44962 in RTreeSearch (N=0x282bc70, R=0x7fff36695ef0,
     shcb=0x7ff01c9cd2e5 <find_cross>, cbarg=0x7fff36695f34) at index.c:65
 #4  0x00007ff01c9cde42 in Vect_line_check_intersection (APoints=0x25949e0,
     BPoints=0x27f1770, with_z=0) at intersect.c:1273
 #5  0x00007ff01c9dc922 in Vect_select_lines_by_polygon (Map=0x26a6d20,
     Polygon=0x27f1770, nisles=0, Isles=0x0, type=4, List=0x28b21e0)
     at select.c:254
 #6  0x00007ff01c9dca3f in Vect_select_areas_by_polygon (Map=0x26a6d20,
     Polygon=0x27f1770, nisles=0, Isles=0x0, List=0x281fbc0) at
 select.c:309
 #7  0x00007ff01d3b121c in QgsGrassProvider::select (this=0x2867dc0,
     fetchAttributes=
         {{p = {static shared_null = {ref = {_q_value = 11685}, alloc = 0,
 begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x7fff366961e0}, d =
 0x7fff366961e0}}, rect=
       {xmin = 6.9531887103213781e-310, ymin = 6.9531887103229591e-310,
 xmax = 2.093279462441127e-316, ymax = 6.9531887103063585e-310},
 fetchGeometry=true,
     useIntersect=true)
     at /home/shoofi/src/straight/qgis-
 trunk/src/providers/grass/qgsgrassprovider.cpp:496
 #8  0x00007ff02de85947 in QgsVectorLayer::select (this=0x2846050,
 attributes=
 begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x7fff36696590}, d =
 0x7fff36696590}}, rect=
       {xmin = 6.9531887103680179e-310, ymin = 6.9531887103695989e-310,
 xmax = 2.0864313173372507e-316, ymax = 1.9466186446145114e-321},
 fetchGeometries=true,
     useIntersect=true)
 trunk/src/core/qgsvectorlayer.cpp:1184
 #9  0x0000000000562833 in QgsMapToolIdentify::identifyVectorLayer (
     this=0x19d1dd0, point=@0x7fff36696ab0)
 trunk/src/app/qgsmaptoolidentify.cpp:270
 #10 0x0000000000565c31 in QgsMapToolIdentify::canvasReleaseEvent (
     this=0x19d1dd0, e=0x7fff36697520)
 trunk/src/app/qgsmaptoolidentify.cpp:104
 #11 0x00007ff02e238253 in QgsMapCanvas::mouseReleaseEvent (this=0x1a149b0,
     e=0x7fff36697520)
     at /home/shoofi/src/straight/qgis-trunk/src/gui/qgsmapcanvas.cpp:774
 #12 0x00007ff02cf9a139 in QWidget::event () from /usr/lib/libQtGui.so.4
 #13 0x00007ff02d49617b in QGraphicsView::viewportEvent ()
 #14 0x00007ff02da22658 in
 QCoreApplicationPrivate::sendThroughObjectEventFilters---Type <return> to
 continue, or q <return> to quit---
  () from /usr/lib/libQtCore.so.4
 #15 0x00007ff02cf47a2c in QApplicationPrivate::notify_helper ()
 #16 0x00007ff02cf5004a in QApplication::notify () from
 #17 0x00007ff02ddf362e in QgsApplication::notify (this=0x7fff36698400,
     receiver=0x198f970, event=0x7fff36697520)
     at /home/shoofi/src/straight/qgis-trunk/src/core/qgsapplication.cpp:78
 #18 0x00007ff02da23381 in QCoreApplication::notifyInternal ()
 #19 0x00007ff02cf4f3e8 in QApplicationPrivate::sendMouseEvent ()
 #20 0x00007ff02cfb3909 in ?? () from /usr/lib/libQtGui.so.4
 #21 0x00007ff02cfb27ff in QApplication::x11ProcessEvent ()
 #22 0x00007ff02cfd9c84 in ?? () from /usr/lib/libQtGui.so.4
 #23 0x00007ff02988678b in g_main_context_dispatch ()
    from /usr/lib/libglib-2.0.so.0
 #24 0x00007ff029889f5d in ?? () from /usr/lib/libglib-2.0.so.0
 #25 0x00007ff02988a11b in g_main_context_iteration ()
 #26 0x00007ff02da4b70f in QEventDispatcherGlib::processEvents ()
 #27 0x00007ff02cfd944f in ?? () from /usr/lib/libQtGui.so.4
 #28 0x00007ff02da21ca2 in QEventLoop::processEvents ()
 #29 0x00007ff02da21e2d in QEventLoop::exec () from /usr/lib/libQtCore.so.4
 #30 0x00007ff02da242dd in QCoreApplication::exec ()
 #31 0x00000000004b5599 in main (argc=1, argv=0x7fff36698af8)
     at /home/shoofi/src/straight/qgis-trunk/src/app/main.cpp:683
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1416>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
