[QGIS-trac] [Quantum GIS] #1417: Unable to add a Postgis layer when the key attribut have an alias
Quantum GIS qgis at qgis.org
Fri Nov 21 05:01:35 EST 2008
   Reporter:  mgrizonnet                        |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  Data Provider                     |            Version:  HEAD
   Keywords:  postgis layer/primary key/alias   |   Platform_version:
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 I created 2 views  VIEW _VIEW0 and VIEW _VIEW1 in PostgreSQL.
 The code:
 CREATE OR REPLACE VIEW _VIEW0 AS
 SELECT
 t1.geom,
 t1.id
 FROM table1 t1
 ORDER BY t1.id;
 SELECT
 t1.geom,
 t1.id as id_geo
 FROM table1 t1
 ORDER BY t1.id;
 It is the same views. The only difference is that the attribute "id" has
 got an "alias" (the alias is "id_geo").
 The data type of id is int4 and it is a primary key (needed by QGIS to
 make the connection).
 The first view works well but not the second. The message returned by QGIS
 is that the attribute "id" is not a primary key (data not unique).
 But it is the same views!!!!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1417>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
