[QGIS-trac] Re: [Quantum GIS] #1420: random freezes when bulit with debug
Quantum GIS qgis at qgis.org
Mon Nov 24 12:33:17 EST 2008
        Reporter:  msieczka                                   |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  GUI                                        |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Linux
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by msieczka):
 Replying to [comment:1 jef]:
 > Did you try to attach to the frozen process to get a backtrace?
 So it happened again. This time whole Gnome freezed - such a total freeze
 happened only once before, as far as I remeber. After killing QGIS from a
 tty Gnome came back to it's normal state.
 Here's the backtrace before I killed QGIS:
 0x00007fdce9a13a2b in write () from /lib/libc.so.6
 (gdb) bt
 #0  0x00007fdce9a13a2b in write () from /lib/libc.so.6
 #1  0x00007fdce99c190a in _IO_file_write () from /lib/libc.so.6
 #2  0x00007fdce99c156a in ?? () from /lib/libc.so.6
 #3  0x00007fdce99c184e in _IO_file_xsputn () from /lib/libc.so.6
 #4  0x00007fdce999ac0a in ?? () from /lib/libc.so.6
 #5  0x00007fdce9996436 in vfprintf () from /lib/libc.so.6
 #6  0x00007fdce999fc08 in fprintf () from /lib/libc.so.6
 #7  0x00000000004b270e in myMessageOutput (type=QtDebugMsg,
     msg=0x7ffff5cb08f0 "/home/shoofi/src/straight/qgis-
 trunk/src/core/qgsmaprenderer.cpp: 193: (adjustExtentToSize), Scale
 (assuming meters as map units) = 1: 1388891.828683") at
 /home/shoofi/src/straight/qgis-trunk/src/app/main.cpp:210
 #8  0x00007fdcecf4e543 in qt_message_output () from
 /usr/lib/libQtCore.so.4
 #9  0x00007fdcecf4e9e4 in qDebug () from /usr/lib/libQtCore.so.4
 #10 0x00007fdced44c1c3 in QgsLogger::debug (var=@0x7ffff5cb2c30,
     val=1388891.8286826622, debuglevel=1,
     file=0x7fdced587f08 "/home/shoofi/src/straight/qgis-
 trunk/src/core/qgsmaprenderer.cpp", function=0x7fdced5884c0
 "adjustExtentToSize", line=193)
     at /home/shoofi/src/straight/qgis-trunk/src/core/qgslogger.cpp:127
 #11 0x00007fdced45b183 in QgsMapRenderer::adjustExtentToSize
 (this=0x1e3fbb0)
 trunk/src/core/qgsmaprenderer.cpp:193
 #12 0x00007fdced45b340 in QgsMapRenderer::setOutputSize (this=0x1e3fbb0,
 size=
       {wd = 1024, ht = 616}, dpi=98)
 trunk/src/core/qgsmaprenderer.cpp:119
 #13 0x00007fdced859228 in QgsMapCanvasMap::resize (this=0x1d92890, size=
       {wd = 1024, ht = 616})
     at /home/shoofi/src/straight/qgis-trunk/src/gui/qgsmapcanvasmap.cpp:52
 #14 0x00007fdced854a69 in QgsMapCanvas::resizeEvent (this=0x1ebe1c0,
     e=0x7ffff5cb3540)
     at /home/shoofi/src/straight/qgis-trunk/src/gui/qgsmapcanvas.cpp:815
 #15 0x00007fdcec5b4f58 in QWidget::event () from /usr/lib/libQtGui.so.4
 #16 0x00007fdcecab117b in QGraphicsView::viewportEvent ()
 #17 0x00007fdced03d658 in
 QCoreApplicationPrivate::sendThroughObjectEventFilters () from
 #18 0x00007fdcec562a2c in QApplicationPrivate::notify_helper ()
 #19 0x00007fdcec56a7da in QApplication::notify () from
 #20 0x00007fdced40e62e in QgsApplication::notify (this=0x7ffff5cb4ef0,
     receiver=0x1e04fd0, event=0x7ffff5cb3540)
     at /home/shoofi/src/straight/qgis-trunk/src/core/qgsapplication.cpp:78
 #21 0x00007fdced03e381 in QCoreApplication::notifyInternal ()
 #22 0x00007fdcec5eba64 in QWidgetPrivate::setGeometry_sys ()
 #23 0x00007fdcec5b0157 in QWidget::setGeometry () from
 #24 0x00007fdcec93b064 in ?? () from /usr/lib/libQtGui.so.4
 #25 0x00007fdcec93b616 in QAbstractScrollArea::event ()
 #26 0x00007fdcec562a5d in QApplicationPrivate::notify_helper ()
 #27 0x00007fdcec56a7da in QApplication::notify () from
 #28 0x00007fdced40e62e in QgsApplication::notify (this=0x7ffff5cb4ef0,
     receiver=0x1ebe1c0, event=0x7ffff5cb3ec0)
 #29 0x00007fdced03e381 in QCoreApplication::notifyInternal ()
 #30 0x00007fdcec5eba64 in QWidgetPrivate::setGeometry_sys ()
 #31 0x00007fdcec5b0157 in QWidget::setGeometry () from
 #32 0x00007fdcec94fd24 in ?? () from /usr/lib/libQtGui.so.4
 #33 0x00007fdcecaecf38 in ?? () from /usr/lib/libQtGui.so.4
 #34 0x00007fdced0526d4 in QMetaObject::activate () from
 #35 0x00007fdced04cfe3 in QObject::event () from /usr/lib/libQtCore.so.4
 #36 0x00007fdcec562a5d in QApplicationPrivate::notify_helper ()
 #37 0x00007fdcec56a7da in QApplication::notify () from
 #38 0x00007fdced40e62e in QgsApplication::notify (this=0x7ffff5cb4ef0,
     receiver=0x1d80fa0, event=0x7ffff5cb4950)
 #39 0x00007fdced03e381 in QCoreApplication::notifyInternal ()
 #40 0x00007fdced06a256 in ?? () from /usr/lib/libQtCore.so.4
 #41 0x00007fdced0667ad in ?? () from /usr/lib/libQtCore.so.4
 #42 0x00007fdce8ea178b in g_main_context_dispatch ()
    from /usr/lib/libglib-2.0.so.0
 #43 0x00007fdce8ea4f5d in ?? () from /usr/lib/libglib-2.0.so.0
 #44 0x00007fdce8ea511b in g_main_context_iteration ()
 #45 0x00007fdced06670f in QEventDispatcherGlib::processEvents ()
 #46 0x00007fdcec5f444f in ?? () from /usr/lib/libQtGui.so.4
 #47 0x00007fdced03cca2 in QEventLoop::processEvents ()
 #48 0x00007fdced03ce2d in QEventLoop::exec () from /usr/lib/libQtCore.so.4
 #49 0x00007fdced03f2dd in QCoreApplication::exec ()
 #50 0x00000000004b5599 in main (argc=1, argv=0x7ffff5cb55e8)
     at /home/shoofi/src/straight/qgis-trunk/src/app/main.cpp:683
 (gdb) detach
 Detaching from program: /usr/local/bin/qgis, process 6438
 (gdb) q
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1420#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
