[QGIS-trac] Re: [Quantum GIS] #1427: GRASS vectors support: memory leak?
Quantum GIS qgis at qgis.org
Tue Nov 25 16:31:00 EST 2008
        Reporter:  msieczka                                   |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by warmerdam):
 One approach to testing if it is an OGR problem would be to run ogrinfo
 against a grass dataset under valgrind and examine what leaks show up in a
 leak report, if any.
 Alternatively, writes a small program or script using OGR that repeatedly
 scans over a grass vector dataset and see if the memory of the process
 grows for each iteration.
 It sounds like you are running against trunk of everything, so presumably
 this does represent a real and current leak at some level of the software
 stack.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1427#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
