[QGIS-trac] [Quantum GIS] #1339: Can't set projection to WGS84 UTM Zone 15N
Quantum GIS qgis at qgis.org
Tue Oct 7 15:41:47 EDT 2008
   Reporter:  vedgewater                        |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  Projection Support                |            Version:  0.11.0
   Keywords:  UTM SRSID                         |   Platform_version:
   Platform:  Gentoo                            |           Must_fix:  No
Status_info:  0                                 |
 Hello there,
 I'm trying to write a python plugin which needs to determine
 georeferencing info for layers.
 I set a layer's projection by right clicking the layer, selecting
 properties and then selecting Change SRS under the general tab.
 I select SRSID 2992 ( UTM Z 15N ) and click apply
 In my python code, I am doing something like this:
 srsID = regionLayer.srs().srsid()
 srsID always comes out as 3344 instead of 2992!
 Other queries through srs() also seem to say the layer is of longlat
 instead of UTM as I tried to define.
 Is this a known issue?
 Regards,
 Vince
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1339>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
