[QGIS-trac] Re: [Quantum GIS] #1176: Transverse mercator south orientated projections not supported
Quantum GIS qgis at qgis.org
Mon Oct 20 06:28:51 EDT 2008
        Reporter:  halfhaggis                        |         Owner:  homann
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.1.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  Yes                               |   Status_info:  0
Comment (by halfhaggis):
 I'm not sure what the right approach to fixing this in qgis is, but using
 the command-line tools cs2cs and proj, I get the correct results for the
 projections with the -m flag. As warmerdam suggests, it appears that axis
 orientation control would solve this.
 I came to this conclusion after extensive experimentation and discussion
 with Gerald Evenden via the proj4 mailing list.
 This [http://lists.maptools.org/pipermail/proj/2008-August/003608.html
 post] and this [http://lists.maptools.org/pipermail/proj/2008-
 August/003620.html post] seem most relevant.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1176#comment:10>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
