[QGIS-trac] Re: [Quantum GIS] #1373: Derived area values from identify tool differ from calculated PostGIS area
Quantum GIS qgis at qgis.org
Wed Oct 22 23:27:30 EDT 2008
        Reporter:  hdus                              |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Vectors                           |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  RedHat
        Must_fix:  Yes                               |   Status_info:  0
Comment (by smizuno):
 Replying to [ticket:1373 hdus]:
 > When I identify a polygon with the identify tool, the derived area
 differs from the calculated area with postgis area(the_geom) function. The
 difference is small but existing:
 > QGIS: 15.516 km2
 > PostGIS: 15.525 km2
 If you are using On-the-fly transformation, the difference is because QGIS
 uses calculation on an ellipsoid rather than plane calculations as PostGIS
 uses for area().
 Without OTF, QGIS uses plane calculations also, but there may still be a
 very small difference.
 This is essentially the same problem as I put in #1219.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1373#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
