[QGIS-trac] [Quantum GIS] #1272: adding a GRASS raster crashes QGIS
Quantum GIS qgis at qgis.org
Tue Sep 2 15:54:13 EDT 2008
   Reporter:  msieczka                                   |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.0.0
  Component:  GRASS                                      |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  Yes
Status_info:  0                                          |
 QGIS trunk r9249, QT 4.4.0, GDAL 1.5.2 + SVN r15265 (stable branch), GRASS
 6.4 + SVN r33223 (stable branch), gdal-grass plugin built from the source
 of the previosly mentioned GDAL and GRASS revisions
 Debian testing amd64
 1. add a GRASS raster map (e.g. 'elevation.10m' from Spearfish6 dataset;
 but can be any other)
 2. crash
 There was no crash in a day or two ago.
 Debug: /home/shoofi/src/straight/qgis-
 trunk/src/core/raster/qgsrasterlayer.cpp: 1554:
 (drawPalettedSingleBandColor) entered.
 trunk/src/core/raster/qgsrasterlayer.cpp: 3850: (readData) calling
 RasterIO with , source NW corner: 0, 0, source size: 1899, 1398, dest
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0x7f1617c567a0 (LWP 24671)]
 0x0000000000000080 in ?? ()
 (gdb) bt
 #0  0x0000000000000080 in ?? ()
 #1  0x00007f1614e3140b in GDALClose (hDS=0x16492e0) at
 gdaldataset.cpp:1924
 #2  0x00007f160619e73d in G_close_gdal_link (gdal=0x1649220) at gdal.c:121
 #3  0x00007f160619149f in close_old (fd=20) at closecell.c:137
 #4  0x00007f16061913b3 in G_close_cell (fd=20) at closecell.c:86
 #5  0x00007f1601af6b50 in GRASSRasterBand::ResetReading ()
    from /usr/local/lib/gdalplugins/gdal_GRASS.so
 #6  0x00007f1601af6edc in GRASSRasterBand::IRasterIO ()
 #7  0x00007f1614e476bf in GDALRasterBand::RasterIO (this=0x15b7740,
     eRWFlag=GF_Read, nXOff=0, nYOff=0, nXSize=1899, nYSize=1398,
     pData=0x16724b0, nBufXSize=32, nBufYSize=32, eBufType=GDT_Float64,
     nPixelSpace=8, nLineSpace=256) at gdalrasterband.cpp:237
 #8  0x00007f1614e47785 in GDALRasterIO (hBand=0x15b7740, eRWFlag=GF_Read,
     nXOff=0, nYOff=0, nXSize=1899, nYSize=1398, pData=0x16724b0,
 nBufXSize=32,
     nBufYSize=32, eBufType=GDT_Float64, nPixelSpace=0, nLineSpace=0)
     at gdalrasterband.cpp:262
 #9  0x00007f16175ce949 in QgsRasterLayer::readData (this=0x15b3710,
     gdalBand=0x15b7740, viewPort=0x1671380)
     at /home/shoofi/src/straight/qgis-
 trunk/src/core/raster/qgsrasterlayer.cpp:3869
 #10 0x00007f16175de189 in QgsRasterLayer::drawPalettedSingleBandColor (
     this=0x15b3710, theQPainter=0x15b7470, theRasterViewPort=0x1671380,
     theQgsMapToPixel=0x0, theBandNo=1)
 trunk/src/core/raster/qgsrasterlayer.cpp:1568
 #11 0x00007f16175deb74 in QgsRasterLayer::draw (this=0x15b3710,
 theQgsMapToPixel=0x0)
 trunk/src/core/raster/qgsrasterlayer.cpp:1243
 #12 0x00007f16175df183 in QgsRasterLayer::drawThumbnail (this=0x15b3710,
     theQPixmap=0x7fff1fd90990)
 trunk/src/core/raster/qgsrasterlayer.cpp:879
 #13 0x000000000066d1e4 in QgsLegendLayer::getOriginalPixmap
 (this=0x15a2370)
 trunk/src/app/legend/qgslegendlayer.cpp:461
 #14 0x000000000066d2e4 in QgsLegendLayer::setLayerTypeIcon
 (this=0x15a2370)
 trunk/src/app/legend/qgslegendlayer.cpp:89
 #15 0x000000000066043d in QgsLegend::addLayer (this=0x1421360,
 layer=0x15b3710)
 trunk/src/app/legend/qgslegend.cpp:477
 #16 0x000000000069a15c in QgsLegend::qt_metacall (this=0x1421360,
     _c=QMetaObject::InvokeMetaMethod, _id=2, _a=0x7fff1fd90db0)
 trunk/build/src/app/legend/moc_qgslegend.cxx:116
 #17 0x00007f161713a764 in QMetaObject::activate () from
 /usr/lib/libQtCore.so.4
 #18 0x00007f16176132a3 in QgsMapLayerRegistry::layerWasAdded
 (this=0x1469560,
     _t1=0x15b3710)
 trunk/build/src/core/moc_qgsmaplayerregistry.cxx:89
 #19 0x00007f1617537bd0 in QgsMapLayerRegistry::addMapLayer
 (this=0x1469560,
     theMapLayer=0x15b3710, theEmitSignal=true)
 trunk/src/core/qgsmaplayerregistry.cpp:83
 #20 0x00000000004b5ea1 in QgisApp::addRasterLayer (this=0x13948a0,
     theRasterLayer=0x15b3710)
     at /home/shoofi/src/straight/qgis-trunk/src/app/qgisapp.cpp:5297
 #21 0x00000000004b751d in QgisApp::addRasterLayer (this=0x13948a0,
     rasterFile=@0x7fff1fd911b0, baseName=@0x7fff1fd911a0, guiWarning=true)
     at /home/shoofi/src/straight/qgis-trunk/src/app/qgisapp.cpp:5335
 #22 0x00000000004ede14 in QgisAppInterface::addRasterLayer
 (this=0x15060c0,
     rasterLayerPath=
       {static null = {<No data fields>}, static shared_null = {ref =
 {_q_value = 2844}, alloc = 0, size = 0, data = 0x9374fa, clean = 0,
 simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved =
 0, array = {0}}, static shared_empty = {ref = {_q_value = 1903}, alloc =
 0, size = 0, data = 0x7f161740d85a, clean = 0, simpletext = 0, righttoleft
 = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d =
 0x7fff1fd911b0, static codecForCStrings = 0x0},
     baseName=
 0x7fff1fd911a0, static codecForCStrings = 0x0})
 trunk/src/app/qgisappinterface.cpp:77
 #23 0x00007f1606bc70c8 in QgsGrassPlugin::addRaster (this=0x153e220)
 trunk/src/plugins/grass/qgsgrassplugin.cpp:413
 #24 0x00007f1606cc780c in QgsGrassPlugin::qt_metacall (this=0x153e220,
     _c=QMetaObject::InvokeMetaMethod, _id=2, _a=0x7fff1fd91300)
 trunk/build/src/plugins/grass/moc_qgsgrassplugin.cxx:98
 #25 0x00007f161713a764 in QMetaObject::activate () from
 #26 0x00007f161664f1c7 in QAction::triggered () from
 /usr/lib/libQtGui.so.4
 #27 0x00007f161664f990 in QAction::activate () from /usr/lib/libQtGui.so.4
 #28 0x00007f161695b03a in ?? () from /usr/lib/libQtGui.so.4
 #29 0x00007f161695b2d5 in QAbstractButton::mouseReleaseEvent ()
 #30 0x00007f1616a224aa in QToolButton::mouseReleaseEvent ()
 #31 0x00007f16166a73af in QWidget::event () from /usr/lib/libQtGui.so.4
 #32 0x00007f1616654e5d in QApplicationPrivate::notify_helper ()
 #33 0x00007f161665d39a in QApplication::notify () from
 #34 0x00007f1617126411 in QCoreApplication::notifyInternal ()
    from /usr/lib/libQtCore.so.4
 #35 0x00007f161665c738 in QApplicationPrivate::sendMouseEvent ()
 #36 0x00007f16166c0719 in ?? () from /usr/lib/libQtGui.so.4
 #37 0x00007f16166bf5ef in QApplication::x11ProcessEvent ()
 #38 0x00007f16166e69cc in ?? () from /usr/lib/libQtGui.so.4
 #39 0x00007f16131dc892 in g_main_context_dispatch ()
    from /usr/lib/libglib-2.0.so.0
 #40 0x00007f16131e001d in ?? () from /usr/lib/libglib-2.0.so.0
 #41 0x00007f16131e01db in g_main_context_iteration ()
 #42 0x00007f161714e83f in QEventDispatcherGlib::processEvents ()
 #43 0x00007f16166e616f in ?? () from /usr/lib/libQtGui.so.4
 #44 0x00007f1617124d22 in QEventLoop::processEvents ()
 #45 0x00007f1617124ead in QEventLoop::exec () from /usr/lib/libQtCore.so.4
 #46 0x00007f161712737d in QCoreApplication::exec ()
 #47 0x00000000004b2dc9 in main (argc=1, argv=0x7fff1fd931e8)
     at /home/shoofi/src/straight/qgis-trunk/src/app/main.cpp:683
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1272>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
