[QGIS-trac] Re: [Quantum GIS] #1262: Point and Multipoint symbols are not drawn centered at location
Quantum GIS qgis at qgis.org
Wed Sep 3 20:38:05 EDT 2008
        Reporter:  smizuno                           |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Marker Symbols                    |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment (by smizuno):
 data_for_1262.zip contains point.shp, multipoint.shp, linestring.shp,
 postgis_create_tables.txt. The PostGIS tables are what was used to show
 the point alignment problem screenshot. The shapefiles created from the
 PostGIS layers and also show the same.
 The CRS for all is EPSG:26915. Use the filled square symbol of size 10.0
 or so for the points. For the linestring use outline width of 0.00 which
 gives a 1 pixel line.
 The point symbols should be centered at the convergence of the three
 lines.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1262#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
