[QGIS-trac] Re: [Quantum GIS] #1277: digitizing with snapping option works verry slow
Quantum GIS qgis at qgis.org
Thu Sep 4 10:43:32 EDT 2008
        Reporter:  gespiel                           |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Digitising                        |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:  XP, sp2                           |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment (by mhugent):
 The most effective way to speed up the snapping is to have a spatial
 index. Otherwise, every vertex of the whole dataset needs to be tested.
 Do you already have an index on the dataset? If not, you may create one in
 the vector layer properties dialog:
 Open vector layer properties dialog, go to tab 'general', press button
 named 'create spatial index'.
 Marco
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1277#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
