[QGIS-trac] Re: [Quantum GIS] #454: fill pattern rendered extremely thick
Quantum GIS qgis at qgis.org
Fri Sep 5 04:01:07 EDT 2008
        Reporter:  tutey at o2.pl                       |         Owner:  mhugent
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Printing                          |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Comment (by msieczka):
 The bug is still present in the new map composer (SVN trunk r9258, QT
 4.4.0, Debian testing amd64).
 See the attached attached screendumps and the output PDF:
 display-OK.png - a polygon in QGIS filled with Dense7 pattern
 composer-OK.png - looks OK in print composer...
 pdf-BAD.png - ...but in the output PDF the pattern is very oversized
 pattern_too_big.pdf - the pdf output itself
 This bug virtually disables pattern usage in print composer.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/454#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
