[QGIS-trac] Re: [Quantum GIS] #1180: Crash on OS X when adding vector layers
Quantum GIS qgis at qgis.org
Sun Sep 7 02:24:21 EDT 2008
        Reporter:  Shanker                                    |         Owner:  telwertowski
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Vectors                                    |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:  10.4.11                                    |      Platform:  OS X
        Must_fix:  No                                         |   Status_info:  0
Changes (by telwertowski):
  * owner:  nobody => telwertowski
Comment:
 This looks like a Qt 4.4 problem. A bug has been submitted to Trolltech.
 The bug is not present in Qt 4.3 (which was current when QGIS 0.10.0 was
 released). A workaround is to build the current QGIS using Qt 4.3.
 Another workaround is to use a symlink instead of an alias for the volume.
 Qt 4.4 will correctly handle an unmounted symlink but you can't double-
 click it to mount it; it's necessary to use the Finder's Connect to Server
 command or some other method.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1180#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
