[QGIS-trac] [Quantum GIS] #1304: Image export dialog uses wrong file name on changing image type
Quantum GIS qgis at qgis.org
Tue Sep 9 08:56:06 EDT 2008
   Reporter:  cmoe                             |              Owner:  nobody
       Type:  bug                              |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.0.0
  Component:  GUI                              |            Version:  HEAD
   Keywords:  image export print composer      |   Platform_version:
   Platform:  RedHat                           |           Must_fix:  No
Status_info:  0                                |
 The image export dialog in the print composer opens always with the last
 file exported as suggestion (eg. 'foo.tif'). If I am changing the image
 type now, let's say to a png, the file name field says 'foo.png'. This is
 correct, but if I save it now, the file name will be still
 'foo.tif'.[[BR]]
 I guess, the problem is, that the focus all the time lays on the last
 suggestion in the file/directory part of the dialog, where this last
 suggestion ('foo.tif') is marked.
 It works if I write anything in the file name field (e.g. delete the 'g'
 on 'foo.png' and add it again). Also the 'foo.tif' isn't marked any
 longer.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1304>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
