[QGIS-trac] Re: [Quantum GIS] #1231: When creating a new GRASS location, QGIS fails loading predefined regions
Quantum GIS qgis at qgis.org
Wed Sep 10 09:38:54 EDT 2008
        Reporter:  marcopx                                    |         Owner:  telwertowski
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  Yes                                        |   Status_info:  0
Changes (by telwertowski):
  * owner:  nobody => telwertowski
Comment:
 The problem was introduced between 0.10 and 0.11 (tested using Mac
 builds).
 The "can't parse" error appears to be unimportant -- it occurs because
 there is no initial selection when the projection list is first shown. The
 routine is called again when a projection is selected.
 The problem, which I don't understand yet, is that QgsCoordinateTransform
 is returning the same output point for any input point. Perhaps some
 parameter is so far off that every input point is transformed into the
 same output point.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1231#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
