[QGIS-trac] Re: [Quantum GIS] #1159: Identify tool with on-the-fly projection can crash
Quantum GIS qgis at qgis.org
Thu Sep 11 22:24:25 EDT 2008
        Reporter:  barryrowlingson                            |         Owner:  telwertowski
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:  Windows 0.10.0-Io (8383)                   |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Changes (by telwertowski):
  * owner:  nobody => telwertowski
  * platform:  Debian => All
Comment:
 Happens on Mac too (and most likely all platforms):
 Debug:
 /Users/tce/developer/qgis/trunk/src/core/qgscoordinatetransform.cpp: 498:
 (transformCoords) Projection failed emitting invalid transform signal:
 Failed inverse transform of
 (-5.84894e+08, 6.4696e+08)
 with error: tolerance condition error
 Warning: Throwing exception
 /Users/tce/developer/qgis/trunk/src/core/qgscoordinatetransform.cpp502
 /Users/tce/developer/qgis/trunk/src/core/qgscoordinatetransform.cpp272
 Debug: Transform error caught in
 /Users/tce/developer/qgis/trunk/src/core/qgsmaprenderer.cpp line 630:
 terminate called after throwing an instance of 'QgsCsException'
   what():  Failed inverse transform of
 Abort trap
 There are two things to fix here.
 1) QGIS needs an exception handler on the main event loop so that an
 exception alert is displayed and the user is allowed to continue without
 crashing.
 2) The Identify code ought to handle this specific exception and report
 "No features found" much as it does if you click above or below the poles
 using an unprojected map.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1159#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
