[QGIS-trac] Re: [Quantum GIS] #1278: Layer transparence in tif format fails
Quantum GIS qgis at qgis.org
Thu Sep 18 15:44:41 EDT 2008
        Reporter:  gespiel                           |         Owner:  ersts
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Rasters                           |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:  xp sp2                            |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by ersts):
  * owner:  nobody => ersts
Comment:
 Hi gespiel! Sorry you are having problems.
 > geo-referenced tif images appears black when change transparence in
 layer properity.
 To me the uniformly gray display, as shown in the PDF example, makes me
 think you need to apply an enhance or "stretch" to the image.
 1) Does your tif look correct outside of QGIS?
 2) When the transparency is 0% does your image look correct/as you expect?
 3) How was your tif georeferenced? Did you use the QGIS plugin? (if yes,
 can you explain the setting you used)
 Is it possible to post a copy of your tif?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1278#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
