[QGIS-trac] Re: [Quantum GIS] #1327: PostGIS layer default value handling is incorrect
Quantum GIS qgis at qgis.org
Tue Sep 23 01:59:34 EDT 2008
        Reporter:  smizuno                                    |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Data Provider                              |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by jef):
 Replying to [ticket:1327 smizuno]:
 > Because the expression is now the text in the entry field, the result in
 the
 > database table is: {{{'This is a test'::character varying}}}
 Not reproducable here.  You'll see that expression for the value only
 while the
 added feature is not saved yet.  After commit you'll find 'This is a test'
 in the database.
 > Another, better way, would be to send a SELECT query using the
 expression for
 > the default value to the database, then using the result in the
 attribute
 > entry field. This is necessary for text types and sequences, and
 probably
 > others.
 This is what happens, when the expression is left untouched for some but
 not
 all features and therefore the column needs to be a parameter in the
 insert
 statement.
 > 2. The default value for for the column used as the object id, when
 defined
 > as SERIAL does not use the sequence. Actually, this isn't done for any
 column
 > defined as SERIAL, even though the attribute entry fields display the
 > "nextval(...)" expression.
 Right.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1327#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
