[QGIS-trac] [Quantum GIS] #1622: Implement capability to add tabs in the main window
Quantum GIS qgis at qgis.org
Sat Apr 4 16:03:48 EDT 2009
   Reporter:  lynxID                           |              Owner:  lynxID
       Type:  patch                            |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.1.0
  Component:  Build/Install                    |            Version:  HEAD
   Keywords:  tabs                             |   Platform_version:
   Platform:  Fedora                           |           Must_fix:  No
Status_info:  0                                |
 Index: python/gui/qgisinterface.sip
 --- python/gui/qgisinterface.sip        (revision 10465)
 +++ python/gui/qgisinterface.sip        (working copy)
 @@ -70,6 +70,9 @@
      /** Return a pointer to the map canvas */
      virtual QgsMapCanvas * mapCanvas()=0;
 +    /** Return a pointer to the main tab widget */
 +    virtual QTabWidget * tabWidget()=0;
      /** Return a pointer to the main window (instance of QgisApp in case
 of QGIS) */
      virtual QWidget * mainWindow()=0;
 @@ -90,6 +93,21 @@
         /** Remove specified dock widget from main window (doesn't delete
 it). Added in QGIS 1.1. */
         virtual void removeDockWidget ( QDockWidget * dockwidget )=0;
 +    /** Add a tab widget to the main window */
 +    virtual void addTabWidget( QWidget *page, const QString &label )=0;
 +    /** Add a tab widget to the main window with icon */
 +    virtual void addTabWidget( QWidget *page, const QIcon &icon, const
 QString &label )=0;
 +    /** Insert a tab widget to the main window with label */
 +    virtual void insertTabWidget( int index, QWidget *page, const QString
 &label )=0;
 +    /** Insert a tab widget to the main window with icon and label */
 +    virtual void insertTabWidget( int index, QWidget *page, const QIcon
 &icon, const QString &label )=0;
 +    /** Remove specified tab widget from main window (doesn't delete it).
 +    virtual void removeTabWidget( int index )=0;
      /** refresh legend of a layer */
      virtual void refreshLegend( QgsMapLayer * layer )=0;
 Index: src/app/qgisappinterface.h
 --- src/app/qgisappinterface.h  (revision 10465)
 +++ src/app/qgisappinterface.h  (working copy)
 @@ -85,6 +85,9 @@
      /** Return a pointer to the map canvas used by qgisapp */
      QgsMapCanvas * mapCanvas();
 +    /** Return a pointer to the main tab widget that containing map
 canvas */
 +    virtual QTabWidget * tabWidget();
      /** Gives access to main QgisApp object
          Plugins don't need to know about QgisApp, as we pass it as
 QWidget,
 @@ -105,6 +108,21 @@
      void removeDockWidget( QDockWidget * dockwidget );
 +    void addTabWidget( QWidget *page, const QString &label );
 +    void addTabWidget( QWidget *page, const QIcon &icon, const QString
 &label );
 +    void insertTabWidget( int index, QWidget *page, const QString &label
 +    void insertTabWidget( int index, QWidget *page, const QIcon &icon,
 +    void removeTabWidget( int index );
      virtual void refreshLegend( QgsMapLayer *l );
      /** Add window to Window menu. The action title is the window title
 Index: src/app/qgisapp.h
 --- src/app/qgisapp.h   (revision 10465)
 +++ src/app/qgisapp.h   (working copy)
 @@ -59,6 +59,8 @@
  #include <QToolBar>
  #include <QAbstractSocket>
  #include <QPointer>
 +#include <QTabWidget>
 +#include <QTabBar>
  #include "qgsconfig.h"
  #include "qgspoint.h"
 @@ -137,8 +139,11 @@
      //!Overloaded version of the private function with same name that
 takes the imagename as a parameter
      void saveMapAsImage( QString, QPixmap * );
      /** Get the mapcanvas object from the app */
 -    QgsMapCanvas * mapCanvas() { return mMapCanvas; };
 +    QgsMapCanvas * mapCanvas() { return mMapCanvas; }
 +    /** Get the tabwidget object from the app */
 +    QTabWidget * tabWidget() { return mTabWidget; }
      QgsComposer* printComposer() {return mComposer;}
      //! Set theme (icons)
 @@ -180,6 +185,22 @@
       * After adding the dock widget to the ui (by delegating to the
 QMainWindow
       * parent class, it will also add it to the View menu list of
 docks.*/
      void addDockWidget( Qt::DockWidgetArea area, QDockWidget * dockwidget
 +    /** Add a tab widget to the main window with label */
 +    /** Add a tab widget to the main window with icon and label */
 &label );
 +    /** Remove specified dock widget from main window (doesn't delete
      /** Add a toolbar to the main window. Overloaded from QMainWindow.
       * After adding the toolbar to the ui (by delegating to the
 QMainWindow
 toolbars.*/
 @@ -814,6 +835,20 @@
          QgsMapTool* mAddIsland;
      } mMapTools;
 +//    class QgsTabWidget : public QTabWidget
 +//      public:
 +//      QgsTabWidget(QWidget *parent) {
 +//        QgsTabWidget::QTabWidget();
 +//        tabBar()->hide();
 +//      void addTab(QWidget *widget, const QIcon &icon, const QString
 &label) { QTabWidget::addTab(widget, icon, label); if (count() > 1)
 tabBar()->show(); }
 +//      void addTab(QWidget *widget, const QString &label) {
 QTabWidget::addTab(widget, label); if (count() > 1) tabBar()->show(); }
 +//      void insertTab(int index, QWidget *widget, const QIcon &icon,
 const QString &label) { QTabWidget::insertTab(index, widget, icon, label);
 +//      void insertTab(int index, QWidget *widget, const QString &label)
 { QTabWidget::insertTab(index, widget, label); if (count() > 1)
 tabBar()->show(); }
 +//      void removeTab(int index) { if (count() != 1) {
 QTabWidget::removeTab(index); if (count() == 1) tabBar()->hide();  } }
      QgsMapTool *mNonEditMapTool;
      //! Widget that will live on the statusbar to display "scale 1:"
 @@ -846,6 +881,9 @@
      QMenu *toolPopupCapture;
      //! Map canvas
      QgsMapCanvas *mMapCanvas;
 +    //! Tab widget
 +//    QgsTabWidget *mTabWidget;
 +    QTabWidget *mTabWidget;
      //! Table of contents (legend) for the map
      QgsLegend *mMapLegend;
      //! Cursor for the overview map
 Index: src/app/qgisapp.cpp
 --- src/app/qgisapp.cpp (revision 10465)
 +++ src/app/qgisapp.cpp (working copy)
 @@ -1548,8 +1548,8 @@
    // Connect warning dialog from project reading
    connect( QgsProject::instance(), SIGNAL( oldProjectVersionWarning(
 QString ) ),
             this, SLOT( oldProjectVersionWarning( QString ) ) );
  void QgisApp::createCanvas()
    // "theMapCanvas" used to find this canonical instance later
 @@ -1557,7 +1557,12 @@
    mMapCanvas->setWhatsThis( tr( "Map canvas. This is where raster and
 vector "
                                  "layers are displayed when added to the
 map" ) );
 -  setCentralWidget( mMapCanvas );
 +  mTabWidget = new QTabWidget(this);
 +  mTabWidget->setTabPosition(QTabWidget::East);
 +  mTabWidget->addTab(mMapCanvas, tr("2D view"));
 +  setCentralWidget( mTabWidget );
    // set the focus to the map canvas
    mMapCanvas->setFocus();
 @@ -1653,6 +1658,31 @@
    mMapCanvas->refresh();
 +void QgisApp::addTabWidget( QWidget *page, const QString &label )
 +  mTabWidget->addTab( page, label );
 +void QgisApp::addTabWidget( QWidget *page, const QIcon &icon, const
 QString &label )
 +  mTabWidget->addTab( page, icon, label );
 +void QgisApp::insertTabWidget( int index, QWidget *page, const QString
 &label )
 +  mTabWidget->insertTab( index, page, label );
 +void QgisApp::insertTabWidget( int index, QWidget *page, const QIcon
 +  mTabWidget->insertTab( index, page, icon, label );
 +void QgisApp::removeTabWidget( int index )
 +  mTabWidget->removeTab( index );
  QToolBar *QgisApp::addToolBar( QString name )
    QToolBar *toolBar = QMainWindow::addToolBar( name );
 Index: src/app/qgisappinterface.cpp
 --- src/app/qgisappinterface.cpp        (revision 10465)
 +++ src/app/qgisappinterface.cpp        (working copy)
 @@ -136,6 +136,11 @@
    return qgis->mapCanvas();
 +QTabWidget * QgisAppInterface::tabWidget()
 +  return qgis->tabWidget();
  QWidget * QgisAppInterface::mainWindow()
    return qgis;
 @@ -169,6 +174,31 @@
    qgis->removeDockWidget( dockwidget );
 +void QgisAppInterface::addTabWidget( QWidget *page, const QString &label
 +  qgis->addTabWidget( page, label );
 +void QgisAppInterface::addTabWidget( QWidget *page, const QIcon &icon,
 +  qgis->addTabWidget( page, icon, label );
 +void QgisAppInterface::insertTabWidget( int index, QWidget *page, const
 QString &label )
 +  qgis->insertTabWidget( index, page, label );
 QIcon &icon, const QString &label )
 +  qgis->insertTabWidget( index, page, icon, label );
 +void QgisAppInterface::removeTabWidget( int index )
 +  qgis->removeTabWidget( index );
  void QgisAppInterface::refreshLegend( QgsMapLayer *l )
    if ( l && qgis && qgis->legend() )
 --- src/gui/qgisinterface.h     (revision 10465)
 +++ src/gui/qgisinterface.h     (working copy)
 @@ -25,6 +25,8 @@
  class QDockWidget;
  class QMainWindow;
  class QWidget;
 +class QTabWidget;
 +class QIcon;
  #include <QObject>
  #include <QPair>
 @@ -104,6 +106,9 @@
      virtual QgsMapCanvas * mapCanvas() = 0;
 +    virtual QTabWidget * tabWidget() = 0;
 of QGIS) */
      virtual QWidget * mainWindow() = 0;
 @@ -121,6 +126,21 @@
      virtual void removeDockWidget( QDockWidget * dockwidget ) = 0;
 +    virtual void addTabWidget( QWidget *page, const QString &label ) = 0;
 &label ) = 0;
 &icon, const QString &label ) = 0;
 +    virtual void removeTabWidget( int index ) = 0;
      /** refresh the legend of a layer */
      virtual void refreshLegend( QgsMapLayer *l ) = 0;
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1622>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
