[QGIS-trac] Re: [Quantum GIS] #1470: Build error in 1.0.0 (linguist problem in French translation), Qt 4.5.0 beta1
Quantum GIS qgis at qgis.org
Thu Apr 16 11:56:04 EDT 2009
beta1
        Reporter:  vince                                      |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.2
       Component:  Build/Install                              |       Version:  1.0.0
      Resolution:                                             |      Keywords:  linguist french qgis_fr.ts
Platform_version:  Mac OS X 10.5.6                            |      Platform:  OS X
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by Pinpin):
 The problem is still there. I compile qgis-1.0.1-2 on ubuntu jaunty and it
 fails on languages files. Here is the log :
 [ 60%] Generating qgis_lo.qm
 lrelease error: duplicate messages found in
 '/home/sperrinel/appli/qgis_1.0.1-2/i18n/qgis_lo.ts':
 * Context: QgsLabelDialogBase
 * Source: °
 make[2]: *** [i18n/qgis_lo.qm] Erreur 1
 make[1]: *** [i18n/CMakeFiles/translations.dir/all] Erreur 2
 make: *** [all] Erreur 2
 and the configure :
 BINDINGS_GLOBAL_INSTALL          OFF
  BISON_EXECUTABLE                 /usr/bin/bison
  CMAKE_BACKWARDS_COMPATIBILITY    2.4
  CMAKE_BUILD_TYPE
  CMAKE_INSTALL_PREFIX             /usr/local/qgis1.0.1
  ENABLE_TESTS                     OFF
  EXECUTABLE_OUTPUT_PATH
  EXPAT_INCLUDE_DIR                /usr/include
  EXPAT_LIBRARY                    /usr/lib/libexpat.so
  FLEX_EXECUTABLE                  /usr/bin/flex
  GDAL_CONFIG                      /usr/local/bin/gdal-config
  GDAL_CONFIG_PREFER_FWTOOLS_PAT   /bin_safe
  GDAL_CONFIG_PREFER_PATH          /bin
  GDAL_INCLUDE_DIR                 /usr/local/include
  GDAL_LIBRARY                     /usr/local/lib/libgdal.so
  GEOS_CONFIG                      /usr/local/bin/geos-config
  GEOS_CONFIG_PREFER_PATH          /bin
  GEOS_INCLUDE_DIR                 /usr/local/include
  GEOS_LIBRARY                     /usr/local/lib/libgeos_c.so
  GEOS_LIB_NAME_WITH_PREFIX        -lgeos_c
  GRASS_PREFIX
  GSL_CONFIG                       /usr/bin/gsl-config
  GSL_CONFIG_PREFER_PATH           /bin
  GSL_EXE_LINKER_FLAGS             -Wl,-rpath,/usr/lib
  PEDANTIC                         OFF
  POSTGRESQL_PREFIX
  POSTGRES_CONFIG                  /usr/bin/pg_config
  POSTGRES_CONFIG_PREFER_PATH      /bin
  POSTGRES_INCLUDE_DIR             /usr/include/postgresql
  POSTGRES_LIBRARY                 /usr/lib/libpq.so
  PROJ_INCLUDE_DIR                 /usr/local/include
  PROJ_LIBRARY                     /usr/local/lib/libproj.so
  QT_QMAKE_EXECUTABLE              /usr/bin/qmake
  SIP_BINARY_PATH                  /usr/bin/sip
  SIP_INCLUDE_DIR                  /usr/include/python2.6
  SQLITE3_INCLUDE_DIR              /usr/include
  SQLITE3_LIBRARY                  /usr/lib/libsqlite3.so
  SVN_MARKER                       SVN_MARKER-NOTFOUND
  WITH_BINDINGS                    ON
  WITH_GRASS                       ON
  WITH_INTERNAL_SQLITE3            OFF
  WITH_POSTGRESQL                  ON
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1470#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
