[QGIS-trac] [Quantum GIS] #1653: Segmentation Fault in FC10
Quantum GIS qgis at qgis.org
Fri Apr 24 12:30:51 EDT 2009
   Reporter:  lookingforoil                              |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  Build/Install                              |            Version:
   Keywords:                                             |   Platform_version:
   Platform:  Fedora                                     |           Must_fix:  No
Status_info:  0                                          |
 I recently attempted to install and run QGIS 1.0.1 on a new install of
 FC10. It was simply installed using yum. Upon running qgis from the
 terminal I receive a segmentation fault.
 A quick backtrace through gdb results in the following:
 Program received signal SIGSEGV, Segmentation fault.
 0x021c78b4 in ?? () from /usr/lib/libQtGui.so.4
 (gdb) backtrace
 #0  0x021c78b4 in ?? () from /usr/lib/libQtGui.so.4
 #1  0x06180162 in g_main_context_prepare () from /lib/libglib-2.0.so.0
 #2  0x061805ea in ?? () from /lib/libglib-2.0.so.0
 #3  0x06180ac1 in g_main_context_iteration () from /lib/libglib-2.0.so.0
 #4  0x01414b07 in link_main_iteration () from /usr/lib/libORBit-2.so.0
 #5  0x013f6d5e in giop_recv_buffer_get () from /usr/lib/libORBit-2.so.0
 #6  0x013fbf46 in ORBit_small_invoke_stub () from /usr/lib/libORBit-2.so.0
 #7  0x013fc179 in ORBit_small_invoke_stub_n () from
 #8  0x0140900a in ORBit_c_stub_invoke () from /usr/lib/libORBit-2.so.0
 #9  0x013cafce in ConfigServer_ping () from /usr/lib/libgconf-2.so.4
 #10 0x013afda7 in gconf_activate_server () from /usr/lib/libgconf-2.so.4
 #11 0x013be309 in ?? () from /usr/lib/libgconf-2.so.4
 #12 0x013bf246 in ?? () from /usr/lib/libgconf-2.so.4
 #13 0x013c0214 in gconf_engine_get_default () from
 #14 0x013c7b78 in gconf_client_get_default () from
 #15 0x024cbb9e in ?? () from /usr/lib/libQtGui.so.4
 #16 0x024cc1c0 in ?? () from /usr/lib/libQtGui.so.4
 #17 0x024cd5dd in ?? () from /usr/lib/libQtGui.so.4
 #18 0x024b17b5 in QGtkStyle::QGtkStyle () from /usr/lib/libQtGui.so.4
 #19 0x02428c22 in QStyleFactory::create () from /usr/lib/libQtGui.so.4
 #20 0x0212c6e8 in QApplication::style () from /usr/lib/libQtGui.so.4
 #21 0x0212c9dd in QApplicationPrivate::initialize () from
 #22 0x0212ca7b in QApplicationPrivate::construct () from
 #23 0x0212d63b in QApplication::QApplication () from
 #24 0x00161b90 in QgsApplication::QgsApplication () from
 /usr/lib/libqgis_core.so.1.0
 #25 0x0809ad78 in main ()
 Also, the initial run of gdb produces the following:
 Missing separate debuginfos, use: debuginfo-install qgis-1.0.1-1.fc10.i386
 An attempt to install the qgis debug reports that it is installed and
 current.
 I have always used Ubuntu in the past and have never encountered any major
 problems so this is a first.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1653>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
