[QGIS-trac] Re: [Quantum GIS] #1855: Postgis View Layers with OID as primary key are loading very slow
Quantum GIS qgis at qgis.org
Mon Aug 3 10:54:06 EDT 2009
        Reporter:  hdus              |         Owner:  jef
            Type:  bug               |        Status:  new
        Priority:  minor: annoyance  |     Milestone:  Version 1.2.0
       Component:  Data Provider     |       Version:  HEAD
      Resolution:                    |      Keywords:
Platform_version:                    |      Platform:  All
        Must_fix:  Yes               |   Status_info:  0
Changes (by jef):
  * owner:  mhugent => jef
Comment:
 Replying to [ticket:1855 hdus]:
 > I want to load a postgis view layer defined in a way that the OID
 represents the primary key of the view query result. No real primary key
 is defined in the source tables. When I query this view from psql it gives
 me the query result very fast. When I load this layer into QGIS it needs a
 very long time, more than 1 minute, to load this layer.
 Does "loading" mean only "inserting" or "displaying"?   Inserting the view
 to the project can be slow, while QGIS tries to figure out what the
 primary key column is.   Once that's done displaying should be quick.
 Saving the project and reloading it should be also quick as QGIS saves the
 key column it found.
 If you add the layer using python you can also specify the key column
 using key=column and QGIS will just verify that it's unique.
 See also #1535
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1855#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
