[QGIS-trac] Re: [Quantum GIS] #1688: Map srs should inherit from first layer added to new project
Quantum GIS qgis at qgis.org
Tue Aug 4 05:52:10 EDT 2009
        Reporter:  springmeyer                       |         Owner:  nobody
            Type:  enhancement                       |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.2.0
       Component:  Projection Support                |       Version:  1.0.0
      Resolution:  wontfix                           |      Keywords:
Platform_version:                                    |      Platform:  OS X
        Must_fix:  No                                |   Status_info:  0
Changes (by homann):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 It means that if there is no information about the CRS for *the layer*,
 what to do then?
 As long as you don't have projection turned on, the map CRS doesn't
 matter. When you turn it on, you also specify the "map" CRS.
 What you suggst was the behaviour a few years back, but I think the
 current situation is cleaner and more predictable.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1688#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
