[QGIS-trac] Re: [Quantum GIS] #1729: MapInfo: OGR layer converter doesn't work
Quantum GIS qgis at qgis.org
Wed Aug 5 04:48:03 EDT 2009
        Reporter:  1969                                     |         Owner:
            Type:  bug                                      |        Status:  closed
        Priority:  major: does not work as expected         |     Milestone:  Version 1.2.0
       Component:  C++ Plugins                              |       Version:  HEAD
      Resolution:  wontfix                                  |      Keywords:  MapInfo Tab and Mif/Mid driver
Platform_version:  Window XP sp3, Ubuntu 8.04, Ubuntu 9.04  |      Platform:  All
        Must_fix:  No                                       |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 I gave a closer look to this and I have to admit that at the end it works,
 at least with the latest development version of qgis under both linux and
 windows.
 It happens that under linux the "dataset" field misses the "browse"
 button, but if you enter by hand the path were the mapinfo files reside,
 then you can click "connect" and see in "layers" the list of available
 ones.
 Under windows there is the "browse" button so no problem at all.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1729#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
