[QGIS-trac] [Quantum GIS] #1861: Help Documentation is Wrong Version
Quantum GIS qgis at qgis.org
Thu Aug 6 14:59:12 EDT 2009
   Reporter:  paulp575                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.2.0
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:  Help documentation                |   Platform_version:  XP Pro w/SP2
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 After installing QGIS v1.0.2.0 on two different Windows computers, the
 help PDF file included with the download links to a help PDF file for
 version 0.9.1.
 I had to manually download the current help PDF file.
 Before copying the v1.0.0 help PDF file to the \doc folder, I renamed the
 existing help PDF file from "userguide.pdf" to "userguide-0-9-1.pdf" just
 in case the process failed. I then copied the v1.0.0 help PDF file to the
 \doc folder.
 That worked!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1861>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
