[QGIS-trac] Re: [Quantum GIS] #1219: OTFT on, layer's and project's CRS the same: measure tools and Identify Features return impossible measurments
Quantum GIS qgis at qgis.org
Tue Aug 11 09:19:05 EDT 2009
        Reporter:  smizuno             |         Owner:  homann
            Type:  enhancement         |        Status:  assigned
        Priority:  minor: annoyance    |     Milestone:  Version 1.2.0
       Component:  Projection Support  |       Version:  HEAD
      Resolution:                      |      Keywords:  measure area line
Platform_version:                      |      Platform:  All
        Must_fix:  Yes                 |   Status_info:  0
Comment (by lutra):
 Hi[[BR]]
 Replying to [comment:12 homann]:
 > OK, I haven't tested with projection in feet, so no surprise there. Can
 you describe what projection and what method you use to test, then I'l be
 able to debug it quickly.
 I used the (Alaska) qgis sample dataset. It is available on the site.
 > The point with display units is that they are for the measurement only,
 and in what unit the user wants to see, and not the format the data is in.
 I personally think they SHOULDN'T change automatically.
 > The scale bar doesn't use the display units at all, it is only for
 measurement tool.
 Ok, for many (who uses projections in meters) would be not a big deal as
 they will have scale bars in meters and measure tools in meters by
 default. But who uses primarily projections in feet will have scale bars
 in feet and then measure tools in meters by default, so they will have to
 go to the options and change the unit manually.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1219#comment:13>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
