[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Sat Aug 15 03:39:50 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  reopened
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by lutra):
 Hi!
 I attached here the example. But look, as I said (maybe not in a very
 clear way) after all could have no problem at all. Two identical layers
 that just differ for towgs parameters do align (regardless if the project
 projection is geographical or projected) depending of the ellipsoid
 defined in the project crs. This could make sense, but again I'm not very
 deep yet with projection matters.
 If this results ok, I guess that also #1079 can be closed.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1875#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
