[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Sun Aug 16 17:22:03 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by neteler):
 Replying to [comment:25 lutra]:
 > When loading the layer defined with B) qgis strips or ignores
 > "+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68"
 > and shows just
 > "+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0
 +ellps=WGS84 +datum=WGS84 +units=m +no_defs"
 So effectively you shift/rotate/scale the map at this point into the wrong
 direction. If QGIS ignores +towgs84, please don't say "fixed" here because
 it isn't. I'll make more tests.
 In GRASS, we have a dialog which pops up for the definition of the datum
 and the user can select the datum. And it is not ignored...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1875#comment:26>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
