[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Sun Aug 16 18:00:02 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by homann):
 Please, can you explain to me what a prj string with both +datum=WGS84 and
 +towgs84 means? I thought both are datum definitions? See for instance the
 output of 'cs2cs -ld', where each valid datum is supplied together with
 the +towgs84 parameters.
 Anyway, proj/GDAL seems not to like both of them and uses the former
 instead.
 Remove the +damtum=WGS84 from proj B, and test. Either +datum or +towgs84,
 but not both.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1875#comment:28>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
