[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Mon Aug 17 11:13:40 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by neteler):
 Ok, I have tested with QGIS trunk from 15 aug 2009. Attached a screenshot,
 the result of a vector projection from Lat-Long (!OpenStreetMap) and
 Gauss-Boaga (provincial data) to a provincial 1m DEM which was made in
 UTM32 look good.
 The prj file of the "viapri" Gauss-Boaga file looks like this:
 # long lines broken for readability here
 cat viapri.prj
 PROJCS["Transverse
 Mercator",GEOGCS["international",DATUM["Monte_Mario",SPHEROID["International_1924",6378388,297],
 TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68]],PRIMEM["Greenwich",0],
 UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],
 PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],
 PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",1500000],
 PARAMETER["false_northing",0],UNIT["Meter",1]]
 I did no longer see the error message in the terminal about towgs84
 confusion of QGIS. Thanks for having this long term issue fixed.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1875#comment:31>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
