[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Tue Aug 18 08:45:49 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by hamish):
 slight update:
  - on the fly reprojection seems to be the culprit of the huge wait to
 render after all
  - now I see the custom crs menu item and can add new ones. the first time
 I tried to edit the generated one my edits were lost after I pressed ok (I
 guess you can only add?). the second time I did the edits and went to
 click on add button but clicked on the star and it was blanked (tooltips
 would help there). The third time I successfully added a second custom CRS
 by hitting the save icon.
  - the EPSG file sets +datum=nzgd49 for NZMG <27200>, but no transform
 options. But in the loading of the shapefile WKT the +datum never arrives.
 ? (I'm not sure if the epsg file is consulted for that; there is no
 AUTHORITY:EPSG stuff in this .prj)
 cheers,
 Hamish
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1875#comment:35>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
